That is looking rather nice!
Looking sweet, is it just me our is 40nm for the front sprocket a bit low, especially with no tab washer to flatten down onto the bolt. I’d be interested in your thoughts
XChallenge ?.........wrong headlight or have I missed something.
Credit to you, you are doing a brilliant job.
Bilko
HP1?! ;-)
Ahh, i wondered where this was going, particularly after seeing the blue frame.
Great reg for this bike. Looking good thus far. Look forward to seeing the finished article.
Thanks Gareth - how goes the engine rebuild/repair ?
Not done much since the weekend as long days at the moment. Decided to swap out the engine for now so i can work on it when time permits; want to be able to confirm the cause before i spend on repair.
Dropped the engine out of the donor bike; removing the lower left frame and keeping the oil tank on. V tight to get out. Thinking of maybe leaving the oil tank in the frame and disconnecting the oil pipes to see if that makes it easier when removing this one (bearing in mind i need to slide another one back in!)
Which way did you find best on yours (plural and possessive 's'!)
I removed the oil tank for the engine removal along with the LH lower frame section but had it and the central frame section pre bolted to the engine for the install
Where did you get the donor bike from - was it that XMoto that was on eBay ?
