sagalout
So after having not a single issue with the bike in almost 6 years, I’m now on the third problem in two weeks!
Bike struggles to start from cold. It turns over fine, but won’t fire properly. When it does it’s as if it’s on one cylinder for a few seconds, then it runs ok. Also experienced occasional hesitation on the road, although this was only a couple of times on a 20 mile ride.
I’ve tried resetting the TPS. Also disconnected and cleaned up all the Power Commander connections (one had a lot of water ingress which I though was the culprit but it hasn’t made any difference)
I’m thinking it’s either a new TPS required or coils. I can’t find anywhere that sells a TPS though - is this only available from the dealer? I read something about them having to be coded to the ECU?
Any other suggestions as to what could be wrong? As my main mode of transport it’s becoming a bit of a pain!
