Wizards-Online
Going Overground
I had the tank off last weekend and the white quick release connector that links the two sides of the 1150GSA tank broke as I undid it and pissed petrol all over the garage floor. I got a replacement set from Motorworks which worked perfectly.
I went for a ride this morning and stopped to see everything was good only to find one of the main fuel line quick release was leaking between the join. I checked Motorworks and a couple of sets with clips works out at £135 (may as well replace both while I'm at it) GULP!!! I'm sure the metal ones are worth every penny, but I just don't have those pennies at the moment, though I did find the replacement O-rings so I've ordered some of those - fingers crossed they do the trick, if not I'll need new ones.
My question is what size quick connects are these so I can look at alternate sources, 6mm or 8mm?
Sent from my SM-T819 using Tapatalk
