rovert57 Well-known member UKGSer Subscriber Joined Aug 23, 2014 Messages 2,324 Reaction score 212 Location WIRRAL Feb 15, 2018 #1 Not long had this lid and only been out with it twice and have noticed that it seems to have a few little rattles ,anyone else found this a problem.
richardbd Well-known member UKGSer Subscriber Joined Aug 25, 2012 Messages 2,577 Reaction score 199 Location Sometimes here, sometimes there... Feb 15, 2018 #2 No. Are you sure it's not your teeth?
SuperTed Active member UKGSer Subscriber Joined Jun 8, 2012 Messages 402 Reaction score 32 Location Romford, Essex Feb 15, 2018 #3 Had an original TourX and an X3. Neither of which rattled. The X3 buzzed after I changed bikes; 1150GS to 800GS; but I tracked that to the peak vibrating due to the different airflow from the 800’s screen. Definitely didn’t rattle.
Jersey_GS Well-known member UKGSer Subscriber Joined Mar 4, 2010 Messages 983 Reaction score 31 Location Jersey Feb 16, 2018 #4 Be careful if you tighten up the plastic visor screws they easily break, have had this happen a few times.
RedRick Esq. Telling Engineer to F**K off since 2023 UKGSer Subscriber Joined Apr 11, 2013 Messages 26,370 Reaction score 1,842 Location Soviet socialist republic of South Yorkshire Feb 16, 2018 #5 If the peak vibrates and buses like wot mine did get some wheel balance weights and keep sticking them on order the leading edge until the vibe stops worked a treat on mine Oh and dont over tighten the screws as has been said they shear easily
