Hi, I’m going to replace my fuel filter on 2003 1150gs, can anyone please tell the size of stainless steel jubilee clip I need.
Many thanks in advance.
Unless someone comes in with something different, 13mm clips BUT make sure they're either the proper crimp-type ones or if you want to use re-usable ones, don't use jubilee clips, use ones which are specific for high pressure fuel-injection systems.
Marc
Thread now closed.
Hope you close the fuel pipes better than this thread !
Should I ask Mickey Boy to do the filter
Alan
If you haven't done so yet here's some tips for you:
Make sure the tank is empty.
When you lift the tank off completely you'll find there are 5 x nasty little fixed bolts holding the pump-unit to the tank sealed with a large 'O' rubber seal (You MUST replace this seal) ... be very careful with these bolts as they will sheer if over-tightened ... if you're in doubt Line 1 applies
Brilliant, thanks for your replies Mike0 & F n F.
Thread now closed.
Many thanks to all for commenting on my post. I’m a fuel filter VIRGIN, Tank off tomorrow, soaking the studs with WD40, while awaiting delivery of the filter, “O” ordered from Motoworks £2 odd, “sorry Steptoe “ for the cost of the O ring on my 15 year old bike I didn’t want to take any chances. Will keep you all posted.Hey, no problem. Always happy to help (not MikeO or fandf)
Bloody hell that is unnaturally clean...
is it, I thought they all looked like this!!
