Screen differences
younger06
Naas, Ireland
What exactly is the difference between a 2007 Adventure screen and a 2010 Adventure screen.
The 4 front mounting points and fixings seem to be different......the later screen has larger diameter holes and metal instead of plastic inner sleeve.
Is there a difference in the side mount/adjustment set up??
I have bought a Puig screen off here and am having trouble getting it to fit on my 2007 Adventure. (I didn't do my due diligence)
I believe the side (bottom) mounts are the same for GS and GSA, but GSA has longer bolts and the inverted U shape support frame. The plastic parts are handed for left & right.
Grommets fit the two holes in middle of screen. I can’t remember if it has special stepped fasteners or if there is a sleeve tube over a normal fastener.
I'll get in touch with Puig and see are there specific fittings for the screen.......the material seems to be thinner than the genuine BMW screen......which is causing me problems.
Sent from a U11
