I noticed when i went to fill the bike at the weekend, that water is pooling in the valley round the filler neck, and the drain hole is full
Ive heard that if you run a strimmer cord down the hole, you can often unblock it
Looking at the exit end, i have two rubber pipes ---
do you know which one of these is the correct one if i want to run a cord the other way?
