fred_jb
ready for some flack, but why is a louder horn needed.
You need to be able to sound like a truck to deter European truck drivers from wiping you out (when they are lane changing in the UK).
As standard the brake light output normally puts out a lower than 12V supply continuously (for the lower brightness rear light function) and ups it to the full 12V to get a brighter output when the brakes are applied. I suspect that if I set the HexEzcan rear light brightness to the same 100% as the brake light output, and turn off brake light flashing, then I will have a spare continuous 12V output which I can use to power some other accessory in future.
I've got a 2013 GS LC and just want to very simply replace the OE horn with a louder one. No brackets, relays or anything else apart from the required canbus lead.
Any suggestions of ones that fit /work?
Ta
Read post 18
Thanks, but the picture looks like it has a relay and a bracket.
I'll also slightly rephrase my question - any suggestions for significantly less than 80 Euros plus postage?
That’s not really plug and play then like it says. I have a hexcan but don’t want to waste a output on a horn. I just had a Denali left over and was seeing if I could use it.
