GOLDRUNWAY 40W LED Auxiliary Lights ..
Buttso
Waterford, Ireland
there are some gems on Aliexpress... found a few over the last while.. bought these for my GSA.. thought I would share a few pics..
so these are the lights
https://www.aliexpress.com/item/GOLDRUNWAY-40W-LED-Auxiliary-Lights-U3-USA-LED-Work-Light-Spot-Lamp-Driving-Fog-12V-Car/32832985649.html?spm=2114.search0104.3.3.56a57608irogtw&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10151_10065_10344_10130_10068_10324_10342_10547_10343_10340_10341_10696_10190_10084_10083_10618_10307_10303_10302_5711215_10313_10059_10184_10534_100031_10103_10624_10623_443_10622_10621_10620,searchweb201603_25,ppcSwitch_5&algo_expid=20738343-6a18-4f59-95f7-665255880f76-0&algo_pvid=20738343-6a18-4f59-95f7-665255880f76&transAbTest=ae803_5&priceBeautifyAB=0
I scanned through the reviews, seemed positive.. They are more expensive than a lot of the ones on there, which tend to be around about 30-50 dollars.. but I have found you do get what you pay for sometimes.
I was contacted by the seller, who wanted to verify the address, and the value they should put on the delivery :D
delivery was 4 days.. couriered to the door by DHL
very impressed with packaging and overall build quality
so this is the unboxing
the entire main loom is all heat wrapped, comes with a relay, micro blade fuse.. and the + and - terminals for your battery.
But I wont be using those parts myself, as I have purchased a Hexezcan... might reuse it for a 12" light bar I am looking at also.
nicely packaged lights
heavy weight in each light, which is kinda nice... good heatsinks on the back
good quality , chunky switch comes with it, that has its own plug into the harness
connected them up to a battery to test them
that gate is about 80 feet away.. roughly
they come with some very nice brackets to attach to your bike, which are also good quality with allan bolts for everything.
they come with a 1 year Warranty.. so happy with that.. so will fit them in a few weeks.. but overall .. very happy..
Shiny pretty things! :drool
:thumb2
must take a look there sometime - i'm looking for an LED solution for the Guzzi, i simply dont have enough electric to go around when it's dark. :blast
They look great, wonder how much UK customs would hammer me for....
What is the blue button for?...... looks like it indicates that it cycles through different modes. If so, what are the other modes?
that flashes the lights .... I will check if it does anything else when its connected to the bike..
