Has anyone else had Problems with Nav 6 losing speed camera notifications on their LC?
Just install the latest Garmin express and upload everything again to your Nav6 this normally sorts many bugs out.
I'm on my 3rd one mate, Garmin keep saying its a BMW issue and vice versa. I hope this new one works ok.
What do you need those for Shaun?
Yep, of course I have
Just a wild shot is your 16gb memory full by any chance.
Haven't had one in since the problem started, thats what we thought it might be, but thanks for the idea Smoggy.
I know that computers when they are nearly full they start to do strange things, that is why Nav6 has the micro sd card slot to act as an automatic overflow, it copies parts of maps and poi,s on both memories if you get a sd card installed, 32 gb is plenty and cheap enough, if you get 64gb you will have to re-format to FAT32, up to 32gb are already formatted at FAT32, stick any micro sd-card in even a small 8gb if you have one around and the re-install everything and see if this fixes the problem, otherwise, maybe like Andy says above, a read/write issue so warranty time.
