Yes. They're is a large grommet. But if you're fitting to another bike (other that the 1200 shown on the site) there are actually lots of large grommets out there. I didn't realise it could come with one so I spent a while looking. So I think finding something suitable would neither be expensive or difficult.
Ian is right, they're pricey from solzy. But it removes any fiddling. I was lazy this time!
But you can buy two of the same lamps from here for less. Found this after buying of course!
www.hq-automotive.co.uk
The really important details are:
a) 'copper plating tech' as they're calling it - this is the key to removing the fan.
b) the white plastic adapt ring that engages with the lamp holder socket. You need this to match your lamp socket type.
c) a less apparent detail is to make sure the LED emitter is in roughly the same position (reach into the housing once fitted) as the element of the regular lamp - easily measured using the socket flange as your datum.
The grommet is the 'fiddle' factor, but I'd expect this to be easily achieved.
All hell of a lot simpler than HID and personally I think the beam is great, I still have sufficient cut-off and very white light.
Sent from my SM-N910F using Tapatalk
cool ill check it out.
