Firstly a little history:
Took the bike for a service and asked about an intermittant problem where the bike would just die with all electrice dead (maybe happens once a ride) and It did seem to blow the rear light bulb (got through 3 in a couple of weeks). It was suggested the problem was probably the Ignition loom. Ordered a new one, fitted it, 30 minute test ride and all seemed ok. Put the bike away.
Back to present day:
Returned to the bike after about a month. It started ok but cuts out after a couple of minutes. The engine then turns over but does not start . If I leave it for a while it will start but then dies shortly after. There is a little buzzing from the electrics and it seems to keep resetting (as if the ignition is being switched on)
Came back next day and exactly the same (and it still is). So I seem to have replaced an intermittant problem with a consistant one! Or is it just a coincendence and something else has gone?
Unfortunately cant get this to the GS expert here as it's unrideable so its going to have to go to my local mechanic so was looking for any pointers I could give him (he has just rebuilt a 1150 GS engine for a customer so should be clued up).
Any ideas?
Sent from my SM-A310F using Tapatalk
Any ideas?
