Tomcat
I've just had new tyres fitted front and rear on my 2015 GS, and now there is a slow leak around the front valve. The leak must have been quite fast when I left the tyre fitters, because after a few miles I knew the tyre was going soft so went back to the fitters. They tightened the hex nut around the valve stem, but said it might require BMW's RDC repair kit to fix. They reckoned it was due to the stem being disturbed when they changed the tyre, plus some corrosion around the valve stem. BMW's RDC kit is £25 for a hexnut, Schrader valve and a rubber seal!! I had a similar problem last time I had the tyres changed (same company).
So, my questions are:
1. Am I just unlucky or are the tyre fitters hamfisted muppets who have damaged the valve?
2. Have other people had similar problems when tyres have been changed?
3. Is there an alternative to the BMW RDC kit (preferably one that doesn't involve taking the tyre off the wheel)?
Thanks, TC
Thanks, TC
