This is going to be some explanation, whenever the "key" is found.
I don't know about these new fangled keyless systems, but if the bike was running and let's say the fob fell out of your pocket somewhere, does the bike continue to run or does it switch off?
D.
It carries on running but unless you’re blind it makes sure you know when the key went out of range by flashing a message up on the instrument panel telling you it’s gone.
The key is on his property (assuming that’s where the bike is) and the only was he’s going to speed up its recovery is by purchasing a replacement. I don’t think a new key, coded to the bike is going to be cheap
