I decided to plug the GS911 into my 2005 R1200GS today.
I had the following fault codes and details.
10167 Output stage to electric fuel pump faulty ( Most likely Fuel pump electronics / driver )
The fault is not present now
10111 Side stand switch
41743 Problem with onboard power outlet, short circuit.
The fault is not present now.
The bike is absolutely fine and I wouldn't of know about these if I didn't have the GS911.
Is there anything in particular I should be checking.
Thanks in advance
Thanks in advance
