kavwexico
Hello all Im hoping for a bit of experience here and a bit of problem solving,
I have had a bad vibration on my 2011 r1200 gsa with 36k kms,
its all over the bike and DEFINITELY the engine thats causing this vibration, it started after I loaned my throttle position sensor to my friend but pretty sure thats a coinsidence , but I also had found out after that I had a stuck closed exhaust valve, which has now been removed,
anyway the bike is pulling like a train and has recently been serviced including valve clearance, ignition coils checked and throttle body sync but still very vibey enough to feel in the hands and feet from 4500 - redline
...............I have nearly exhausted everything I can think of with out stripping the engine, I have a question about the cam shaft tensioner, there is a lot of movement on the cam rail/guide up and down as if the tensioner is failing, when I rotate the engine, is this normal????????????
or is my paranoia driving me mad................has anyone else had this problem and what cured it
