Yes - these are the ones I fitted:
https://www.ebay.co.uk/itm/32mm-Fro...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Excellent quality, and bring the bars both up and back a substantial amount. This means I don't have to lean forward quite so much to reach down to the bars, and this changes the angle of my back just enough to avoid aggravating my back problem.
The only fitting issue I had was that the left side clutch line was just a bit tight on full lock. In reality it would probably never have caused a problem, but being a bit of a perfectionist I decided to re-route the cables and lines on both sides to be outside the fork - easily done by briefly releasing the stanchions and dropping them a couple of inches out of the yoke to pass the cables over them, before bolting them back in place. I also released the lines from their original zip ties which hold them towards the centre of the bike and instead tied them towards the outside so that they are less bent and flex as little as possible as the steering moves.
Fred
