commandoallan
Morning All,
Another few quick questions this time regarding the suspension. I have removed both bolts on the rear suspension and the bottom bolt on the front for fitment of my new units next week. Rear swing arm is supported with the wheel off but the rear shock is not coming loose at the bottom mounting point, is there a collar at the bottom that requires removal and if so how?
I am about to remove the tank to access the top bolt on the front shock then that shock will be removed also, any tips on this?
Cheers All.
Cheers All.
