- Joined
- Dec 20, 2004
- Messages
- 33,471
- Reaction score
- 457
Stalled mine the first time I used it
Don’t do that fully loaded, two-up, on an up hill right hand hairpin in the Alps - it’s scary!
Makes me nervous just thinking about it
It’s a good thing especially when fully loaded two-up on a inclined bend as Smogbob says - however I find it a tad disconcerting just how many revs you need to pull away smoothly without stalling, practice I guess.
Then stop thinking about it and taking any notice of a bod telling you how scary it is.
If you can pass a motorbike test, you can go up and down hairpins, one up, two up, with or without luggage, on a modern motorcycle..... and quite a few old ones, as you’ll see when you get to the top.
A friend of mine has, to all intents and purposes, one arm.... his left. He takes his teenage granddaughter touring in the Alps as a pillion. He’s an OAP. If he can ‘Do the Stelvio’ and all the other passes, with her, their luggage and no use at all in his right arm.... you can do it, too.
I have ridden one of his bikes, which he converts himself (one handed DIY, made harder as he is / was naturally right handed) to have the throttle on the left. The clutch stays as it is. He dumps the front brake lever but leaves it in place for when he converts the bike back to re-sell. The front and back brakes he links to work just off the foot brake, usually dumping a disc on a twin front bike, as it’s difficult (for him at least) not to ‘over-brake’ using the foot pedal. They are not easy to ride, made harder that it’s tricky to countersteer with only one arm.... you end up opening or closing the throttle, until you sort of get the nack of it.
PS He wasn’t born with the impediment. He lost the use of his right arm in a crash, when a bloke coming the other way on Kawasaki lost it on a bend, slid across the road, striking my friend’s bike amidship and snapping it in half. I would guess he was then in his mid-to-late 50’s, so a steep learning curve.... no hairpins are steeper or sharper than that!
I find it a tad disconcerting just how many revs you need to pull away smoothly without stalling.
The easiest way is to pull the lever again, just as you want to set off. It'll disengage the HSC for you. Much easier than all that noisy revving nonsense.
The thing I find most disconcerting is when you engage it and then turn the engine off - roadworks traffic lights for example. As soon as engine is off, the HSC disengages!
I will have to try that, more experimentation required.
Not sure what happened with your RT but it's not possible a GS911 activated it. I thought Hill Hold came standard on the RT, it does here anyway
I dont know, before no H on the dash after I had a H.
Is it possible to switch it on or off in the menus? I didnt look yet.
Maybe you just did not give the front brake a hard enough pull in, as to get the H on the dashboard, it needs a good sharp pull, bit like emergency braking, if that makes sense.
That handle has been well pulled.
Is it now standard on the 1200gs exclusive.
I am running mine in and held the brake ping up it came ��
I was going to pay for it.
