I have use this for years on many other bikes and cars electrics with no problems
Their site quotes
It will protect electrical joints, plugs and components and prevent corrosion causing high resistance joints. This goes for PCB’s and electronics as well, such as computerised ignition and fuel control units and their multi pin plugs, while switches, controls and levers will all be lubricated as well as protected from corrosion. Multi pin plugs and connectors benefit from having ACF‐50 applied directly to the contacts.
