sparky 2010
Hi, Lets try this again, I had my bike stolen but was lucky I got it back same day. No real damage it was towed away by a quad, only thing they did was force the bottom of the ignition barrel the part with the small micro switch in then they jammed a blade in the ignition and damaged this part. I have drilled the two anti tamper bolts and removed them, now I'm stuck because the key won't turn so i can't get the barrel out to repair it. Is there any fix for this? Also i have seen on Ebay a used lock set with key and a control box, is this my only option and is the key paired with the control box?
Ian.
Ian.
