markpaulsm
VSYS 2CH camera recording systems are designed especially for motorcycles. Aimed to simplify the use of cameras, for security, and pleasure. A set of 2 waterproof, wide-angle camera system is installed on the motorcycle or scooter. Powers through bike’s battery never need to be charged. Starts automatically with your ignition, or any movement (smart power module) and turns off once the bike is not being used. Super capacitor design instead of Li-ion battery to avoid battery explosion and be more friendly to environment. Install and forget it, just enjoy the ride!
Here's some features of our lasted model M2F :
• Dual 1080P @30fps Full HD recording: Allow to capture both Front & Rear view high resolution footage.
• Sony IMX323 CMOS image sensor + 6-layer glass lens: Brings a super sharp image quality, better light transmission, records crystal clear video.
• 140/170-degree wide-angle lens: Provides expansive shooting coverage with minimal edge-to-edge distortion.
• Metal housing: Designed with steel housing to disperse heat away from internal circuit (Suggest the main unit be placed under seat if without a waterproof box; Mount it to handlebar when attaching with a waterproof box).
• Waterproof Solution: IP68 water resistance design for lens and wires, plus rainproof case for main unit.
• Built-in Wi-Fi with mobile App: Makes it easy to connect to wireless devices..
• Loop recording: Allows continuously recording by overwriting the files (the record time period can be set to 1/3/5 minutes in the menu).
• Emergency Recording: Support Emergency Recording Mode(G-sensor) and one-button Manual Event Recording(wired remote)
• Auto Power On/Off: Start automatically with your ignition, or any movement (ACC/smart power module) and turns off once the bike is not being used (keep recording about 3 minutes after your bike not being used for smart power module).
• Super Capacitor Design: Without risk of battery explosion and with much longer life compared to lithium battery. Power through motorcycle’s battery never need to be charged. No need to worry about charging problem at all.
• GPS tracker: Check the GPS information (speed, coordinate, route) in Google map when you playback the video in GPS Player.
• Wired controller: Check system status; lock the recording clips by pressing any button.
You can get more details from our online store: https://sysmotocam.aliexpress.com
