Just took delivery of a new to me 2016 LC, freshly serviced from a main dealer and only 3500 miles. There seems to me to be a lot of movement on the brake lever before anything actually happens, this is not slack, it is set within tolerance, there is pressure on the lever but no effect until its maybe 15mm from the bar. The brakes work fine and the lever does not touch the bar, but it does not feel right to me. I have also adjusted the span, but this makes no difference. I mentioned it to the dealer and they tell me all is in order as the brakes perform as they should. Is this normal for this model.
