Squigles Registered user Joined Jan 7, 2015 Messages 128 Reaction score 0 Location London Aug 12, 2018 #1 OK Need to replace the rubber 'O' ring on the master cylinder end of the clutch hose. Would replacing this require a bleed of the system or not? Cheers Tom
Deleted account 181015001 Registered user Joined Feb 11, 2018 Messages 895 Reaction score 0 Location UK Aug 12, 2018 #2 I would think so, I am sure the system doesn't use normal brake fluid I think it uses Hyspin V10 check first before refilling.
Karlos Registered user Joined Jul 7, 2017 Messages 241 Reaction score 1 Location Peterborough Aug 12, 2018 #3 Yes, without a doubt a full bleed of the system is required. Good job it’s the clutch and not the brakes, as that requires the abs pump to be run, whereas the clutch is straight forward. Sent from my iPhone using Tapatalk
