to wire spotlights to come on with main beam done it on previous bikes but not on a bike with canbus.thanks in advance for the help and piss taking by the way its a 2015 gs lc
Does yours have an led headlight, most lighting circuits have bulb monitoring and fused electronically, using a hex easi can or similar as fred mentioned might be best if you do,
Yes the Hex or its Denali brother are no-brainers. Fitting takes moments to connect, routing the wires without removing the bodywork takes considerable longer. About the same as taking the bodywork off and replacing...............
