Need to go out and try it as soon as I can
My 2016 does this too. Rain = Soft; Road = Normal; Dynamic = Hard; but as you say, you can then change the rebound damping setting and it will remember it until the next mode change.Yes it is.
Riding modes on 2017 onwards changes everything not just throttle settings. It changes suspension, traction control and ABS settings.
You can customise by choosing the mode and then changing the suspension (if you want quick throttle but softer suspension).
Neil
Mine doesn’t resetBike normally resets itself back to default settings if you turn the bike off, unless you use that enduro pro plug, then it keeps the last settings, I found that out the hard way ............
Mine doesn’t reset
