On my R1200gs lc 2013 enduro the modes don't always change at first pull of the clutch lever has anyone else had this problem Im hoping its just the microswitch on the clutch
Eh? You can change modes on the fly. You don’t want to be freewheeling for 15 seconds!Hold it in, shut throttle, wait for 15 secs.
You should hear a click just after you depress the clutch as there are two micro switches. If not then a switch adjustment is needed.Im holding it in long enough for sure and sometimes it won't change. It used to be fairly quick and im doing the same thing. I can hear it click when it is nearly fully depressed and also when its around 10mm in so i'm sure the clutch lever is fine
No need to close the throttle on my 2018 bike, just select using the mode button, pull and release the clutch lever, job’s a good ‘un.
