Just got back from the HardAlptour on the XChallenge. Bike did pretty well with the exception the engine would occasionally cut out and wouldn't idle- a real pain in the arse as you roll into a tight hairpin, and find you don't have the power to drive through and out.
Don't think it's valves, more like an ignition problem (the chaps following mentioned a strong smell of fuel when it was messing about), and also the odd pop back through the exhaust.
I seem to remember there is a pick up by the flywheel that picks up swarf, shorting itself out? is this likely to be the issue, and if so does anyone have a photo of the offending item?
Or is it likely to be the coil packs dying? bike has only done 25k miles....
