yamasaki
Haven’t been out on the bike for a while but it’s also just recently been serviced (BMW). Went for a wee run yesterday and when I was wheeling the bike into the garage I noticed a rubbing sound from the back wheel. It wasn’t constant but sounded more like a tight spot and rather like rubber, as opposed to a brake pad binding sound (though I will give the breakers a quick check, these were also cleaned and serviced, bu BMW)
I had a quick look last night and found the swing arm to be fair warm most of it’s length I haven’t noticed this before so wondering if this is normal or a sign of something expensive!
The tyre was warm ( normal) and the rear disk had some heat but did feel cooler then the hub/ Swingarm. There wasn’t any unusual wear marks on the tyre and nothing seemed to be snagging the tyre or wheel.
So any help with what it might be and likely fix?
