Yet another battery.
Like a couple of previous posters I’m not a fan of battery tenders. Never used one. Never replaced a battery on any of the modern bikes I’ve had since 2000. JJH
Regardless of the battery maintainer. The bike ran perfectly 5 weeks ago on an all day ride. Is it normal for a battery to completely discharge on bike? With ignition off what kind of leakage would be expected. I have no sat nav or any other equipment fitted.
Or is 5 weeks unused normal to have to recharge?
Over the winter I put mine on charge for 24 hours, if bike has not been ridden for a month, using Optimate 4 and directly connected to the battery, I do not use that weird canbus plug, otherwise no charger needed when bike is ridden, however my bike is a GS LC
Do you use any kind of charger when not riding? JJH
Yes I’ve always used an optimiser or similar. First battery lasted circa 3 years (decent enough life), second was an Odyssey which after about 3 months generated a fault which put the bike into some sort of emergency mode of operation, 3rd was a motobatt which wrapped its hand in a week before its warranty expired. Now on a BMW (extortionate price) battery. Watch this space!!:thumby:
I think the longest I’ve left my bike is 3 weeks without use. I have an alarm. Bike is kept in a block built garage. I cannot see why 5 weeks would be a problem for a healthy battery. The only comparable example I have is my lawnmower which lies idle from now till March. I will give it 24 hours on a ordinary 12 volt charger around Christmas. The last one lasted 13 years. Now I like to make the comparison of a 1200cc twin cylinder high compression bike engine and a 4 cylinder fairly high performance car. Very few car engines have a compression ratio as high as the bmw engine. When you press the button/turn the key by far the greatest resistance the battery and starter motor has to overcome is pushing that piston up or along that bore against the compression. On a 4 cylinder car engine you still only have 1 cylinder on the compression stroke. Also you usually have a much bigger battery. That is why I liken starting a bmw is like starting a 2.4 liter car but you also have a higher compression ratio to contend with. The battery must be in tip top condition. JJH
The R1150 does not fully charge an AGM battery. I’ve had an ‘01 and an ‘04 and in each cash I modded the vreg to boost the alternator to charge at a higher (correct) voltage. I also use a charger designed for AGM. When I realized the AGM batteries needed a higher charging voltage, I reconditioned both PC680s by discharging them to 10 volts and then fully recharging them, 5 times.
The battery on the ‘04 is now 7 years old and good as new and the battery on the ‘01 is at least 6 years old and in great shape. Both hold a full charge.
