Thats exactly what i did
Yep, me too. Got my farmer mate to siphon it out, filled with super unleaded and rode off.... bit smoky for 10 miles but then all good. at the BP station too...
The filter built into the pump housing holds a fair amount of FUEL.
This is a non replaceable filter as it comes as part of the pump.
As previously suggested best to disconnect the return line on the top of the tank and remove the quick disconnect fitting add a piece of hose to a jar.
cycle the ignition a number of times until the diesel is cleared from the filter.pipes & pressure regulator.
Haynes manual !How accessible is the return line? Is it a tank off job, or just removing body panels?
Just remove the panels left hand side as you sit on the bike There are 2 pipes 1 delivery 1 return.
The return is the one that has NOT had the BMW bodge done to it ( BMW bodge = steel sleeve pressed onto / around the boss where it exits the tank)
Haynes manual !
Other ones are also available for purchase.
Unplug the fuel injector connections while cycling the ignition. This stops any diesel fuel being pumped through the injectors into the cylinders.
Is that a simple quick disconnect of a pipe, or a matter of unbolting stuff?
Unplug the electrical connector on each fuel injector.
Here you go this should help you out.
https://advrider.com/f/threads/empty-the-gs-fuel-tank-the-easy-way.85673/
Thanks, but thats for the older 1150 model isn't it?
Ok, thanks. I’ll have a look at removing the correct pipe tomorrow. As for draining both sides of the tank, I have no idea as I couldn’t really control where the pipe went once it entered the tank. I did however drain about 7 litres, which is probably as much fuel as was in there.
