- Joined
- Mar 24, 2017
- Messages
- 21,761
- Reaction score
- 608
On 1100/1150's and K's the gaiter lasts for years, until they changed the swingarm design..............on all 1200's from 2004 onwards
The gaiter on this bike should last years as well, but it appears it makes contact with the spinning shaft drive at times, causing friction and heat to split the rubber.
It's worse because the split is in the most difficult place to see, right at the bottom of a crease (nearest to the shaft knuckle), and only visible if opened up.
You'd have to dig around in there to spot it, and mine was only 3-5mm in size !!
Fookin nightmare !
