fred_jb
It,s all about the look, you are either hardcore or not.................... give me alloys anyday.
Whatever you mean by hardcore, if you are only buying them to look hardcore, then it probably means you aren't!
Not sure why road riders buy bikes with spoked wheels, maybe it's because unlike the GS the GSA doesn't have the option of cast wheels?
Looks like BMW have released dates of affected bike build dates. It appears to affect bikes built between February and June 2018 https://motorbikewriter.com/crash-prompts-bmw-spoked-wheel-probe/
Won’t stop me routinely checking my July 2018 built bike.
The RSD Manual does not have an instruction to apply locktight, granted it may hold the nipple in place however you would not be able to set the correct torque again unless you removed the everything from the threads.Reading the linked story, the affected bike was a -16, which is not part of the batch mentioned in the BMW bulletin. Further it says that the rider had the spokes checked by the dealer at 3000 km, and the crash happened 2500 km later. For the spokes to be loose this close after a check makes one suspect if the dealer caused the problem during the check? If they unscrewed the grubscrews, did they reapply locktight, as prescribed in the manual? This is speculations only, but honestly, for the wheel to collapse the spokes have to be really loose, and lots of them...
I love my spokes...it started with a chopper...the pedal variety
I could'nt afford a Chopper, I had a Tomahawk.... which nearly killed me, it needed a steering damper !!
tomahawk was half the size of the chopper no wonder you had handling issues,should have started with the chipper first
Or just dump those wheels and switch over to alloy wheels like I've done.
Easier to clean, much less maintenance, lighter and much safer for road use.
Get alloy wheelsets off eBay for around £600.
Quick on the uptake, aren’t they
