flytoolow
Well,
I’m in the process of trying to access an alternator on a 1150 GSA so that I can replace the voltage regulator and hopefully in the process troubleshoot why the charge circuit is intermittent. I’m hoping that during this I will find a bad connection or loose wire somewhere…
Upon reading the Clymer’s manual it’s “simply” a case of :
Tank off – Check
Battery out - Check
Front strut removal – unsure why ? But seems easy enough…
Engine management block out – easy, a few clips and unscrew and it should pull out.
ABS Pump removal – Hmmm
The manual states that after putting the ABS pump back in place I need to Trailer the bike to a BMW garage to get them to bleed the ABS system ? Is this true. Is it not possible to bleed the ABS circuits myself. Are there any specific tools/techniques required?
If I need to get a BMW garage to do it, then I may as well stop here and just ride the bike there and have done with it? Any opinions for a mechanical Orangutan ?
TIA
F2L
Tank off – Check
Battery out - Check
TIA
F2L
