What Optemiser Battery Maintenance Thingy do I Want?
The OP asks "What Optimizer Maintenance Thingy do I want"?
There are several products out there, but to make life easier I would like to narrow down the choices to three.
- Optimate 4 CAN bus edition
- CTEK XS 0.8
- BMWs own CAN bus charger.
CTEK:
This is the cheapest of the lot. According to descriptions it does a fine job bringing a low battery back to life. Limited desulfatoring abilities and it is made to be connected for a long periode of time with a sleep mode and 10 days between checking the battery. Does not handle the BMW aux outlet, a direct to battery cable is required.
Optime 4:
This is the most advanced charger of the lot. In addition to the regular charging cycles it has a recondition desulfator program. You may use the AUX outlet. For the desulfator procedure, the battery must be disconnected and direct connection to the battery is required, as the desulfator voltage is too high for the bikes electronics. A built in check prevents the procedure to be performed while the bike is connected.
BMWs CAN charger.
Does pretty much the same as the CTEK, but may be used through the AUX port and has a LCD display that shows status in plain language.
CTEK is the cheaper, BMWs charger is the most expensive.
CTECK is a fairly simple charger, but in order to keep the battery alive during the winter it will probably do a fine job. Hook it up and leave it on until the spring comes
The Optimate is the one with most advanced options. In order to use all of them, the "Extra" requires the battery to be disconnected.
As long as the battery is connected all the mentioned charger does the same job, more or less.
CTEK has a very basic display, but easy to understand.
Optimate have several LEDs, but may be confusing to understand. You really need to keep the manual available in order to understand it. (Or you can trust that it works and drop the manual)
BMW charger does not do more or less to the battery than the others but has a two line display that says what it's doing in plain language. It may be used either through the AUX port or direct to battery cable. It does not handle the AUX plug better or worse than the Optimate.
Usually, if there are issues by using the AUX port for charging the problem is on the bike side of the plug.
The CAN-bus ability is merely that a charger usually does a test of the battery prior to charging. If connected to the CANbus, the port is closed and as the charger senses nothing, it will not start a charge.
The CAN bus connect procedure starts by applying 12V to the plug. This will signal to the ZFE that there is a charger on line, and ZFE opens up allowing the charge to begin.
However, some of the charge cycle consists of pulsing the battery, and this may be done to a certain extent. But if the low-voltage of the cycle is too long, the ZFE close the port.
As for using the Aux plug or a direct connect cable, my choice would be a direct connect cable. Aux plug sounds tempting, but it limits the charger the ability to properly monitor the battery as the current is routed through the ZFE in the bike. If the internal GPS plug is used, the AUX port may not open up for the charger. All in all, do your self a favour and forget about the AUXport (yes I know, it is possible to make it work, but there is always the chance for it to screw up.) Also, with a direct to battery cable you may use it to hook up equipment that requires more than 5A, e.g an air pump.
Good stuff. I'd just add that there are more CTek chargers than the 0.8, which is only their most basic. If you go CTek, there are better models with cleverer programmes, more comprehensive indications, specific settings for large (car) or small (bike) batteries, an algorithm for AGM batteries. CTek are not the bottom of this pile and, as stated, manufacture the BMW branded ones as well as those of other high end motor manufacturers.
If you are going to change the battery later on from a gel type to a Li-??? type, which has several advantages over the lead acid and gel types, you should consider if the charger/conditioner you are about to purchase is suitable to charge these Li batteries. I know CTEK can but not sure if the Optimate 4 can. Check the specs.
As for CANBus chargers/conditioners. There is only so much juice you can pump down a wire designed to carry 5v signals or have a 12v outlet. Best thing is to forget about connecting to the CANBus and just have a fly lead on the battery. That way the battery can be charged when flat or conditioned in storage without having to worry about issues with the CANBus.
Optimate has a special charger for the Lithium batteries, the Optimate 4 cannot do Lithium, I have been down that road already, expensive lesson..........;)
Batteries.
Oil.
Tires.
Everyone's an expert and these threads (length) go round the earth at least 2 times per year..
I buy original...easier without having to listen to any BS from anyone here.... plus it has warranty. Engineers already did the compatibility tests for me.
That's my advice.
Sent from my MI MAX using Tapatalk
Batteries.
Oil.
Tires.
That's my advice.
Great news, so we can close the forum then....................:blast
Batteries.
Oil.
Tires.
That's my advice.
Maybe some people want to buy a charger they can use on other bikes and cars? There is nothing particularly special about the BMW charger
I use a Ctek lead to connect to the battery that also contains a series of three leds ala traffic light system giving quick and easy idea of charge level. Think it’s called a comfort lead.
I’ve bought a number of these and have equipped each car and the bike with one.
Now running lithium battery on bike and use an Aldi/Lidl digital charger with a Ctek connector and has 3.8A capabilities.
Happy experiences so far.
Again my thanks for all the very positive comments and advice posted above, it really is appreciated.
In terms of cost the Ctec is £20 cheaper than the Opti 4.3 on offer at Nippy Norm’s so I’ll probably go for that one.
I’m off to the show on Monday so I’ll hang fire till then as, you never know, there might be a better offer.... but I doubt it.
Thanks again,
MM
Thanks again,
MM
Black friday will be worth waiting for...........:D
