Can anyone confirm if the Akro end can from a 2018 GS (euro 4) will fit the new 1250 GS?
Hi , I ran mine sunday 300 miles all fine (euro 3) the ecu will adapt to the fuelling , but was advised to keep the baffles in ( BMW) , it ran fine , if you de cat it I would recommend a re map .
Thanks. Alan Jeffries have just confirmed that as well and will swap my can over onto the new 1250 I've ordered for March 1st.
In the "old days", that would be a brilliant idea. For the LC boxers, and probably also the first generation 1200, there is no point in remapping. Whatever map you put in, it will be re-adjusted by the adaptive map, unless you disconnect the O2 sensor, which will throw a fault code.
So, if you want to change the header, go ahead, no worries. The engine works out the new fueling by itself, cat or no cat, it makes no difference.
I'm leaving the baffles in. At a bike check stop by the police in Austria this year they were checking the exhausts for compliance. Quite how they could tell without and measuring equipment I don't know! but luckily they saw my baffles in-situ and thought I was a goody two shoes.
I thought the adaptive map only works so far for minor adjustments , no baffles exhaust + de cat header would make a bike that is already lean even leaner . Would the map installed be the ideal by BMW and the Euro laws ie lean and may not be able to adapt that far , just a thought as I have always remapped when running a full system , but I may be wrong. So an adjusted map ie richer would then self adjust as you say for the new exhaust (full system).
