1100 sticky throttle sorted
ssray
Stourbridge
Thanks to you lot on here, it was that heavy that after 10miles I was in pain, turns out it was friction between the barend weight and the throttle tube, took longer to find a spacer/washer small enough but with a large hole in it than to search it on here
Thanks chaps
Ray
Actually, it's easier
To fix the problem correctly by loosening the throttle twistgrip clamping screws and moving it inwards 1mm.
