G/S project... sort of
Sorry if this is a bit long but I'd best do a quick intro first since I'm new to the airheads forum.
I was on this site a few years ago, mainly in the G650X forum when I owned an X-challenge which, after 46k miles and several modifications, I eventually sold to buy a road bike and lighter dirt bike. After that I rode an ex-Dakar finishing XR650R for a few years - sort of similar to the X-challenge but a bit lighter and racier. I brought this bike with me when we moved to Cyprus in 2015 and despite not being quite as civilised as the X-Ch I managed to ride it 1000 miles through Turkey to Greece, complete the Serres Rally and then return 1000 miles back in a day. I really like the 650 class bikes but it was eventually sold as in Cyprus my riding was increasingly over very technical terrain. I swapped to a 2 stroke dirt bike but wasn't really gelling with it but then had a slight mishap - I went head on with a crew-cab who was on the wrong side off the road.
So that brings me to my airhead - I would call it a G/S but it is actually a bitsa bike with an ST frame, G/S engine, GS forks and wheels which I brought out here in Novemeber. I don't need to explain the charms of an airhead here but after riding with a mate who had a well sorted airhead bike many years ago they have always been on my list of bikes to own when the time was right. After 4 sets of surgery I am able to ride but not strong enough to head up the side of the nearest mountain but I felt bereft without a bike in the shed. What better time to undertake a project... So along came a bike which, since it was already for from standard, I could modify and hopefully improve without feeling guilty.
I have already done a few wee jobs on the bike - sorting sticking chokes and helicoils in the drive shaft fill and drain bolts - and am planning the next steps. What I want to do is update suspension at both ends then see where it takes me. A baja style rear fender and lighter silencer are possible, as is a capacity increase eventually but probably not unless the current engine parts wear out. Since I am on a budget this will be done over a period of time.
So to the suspension and a few questions.
I know the GS forks are an improvement over the original G/S front end but I still find them jarring my wrists over speed bumps in a way that my more recent bikes never have. I have tried lighter oil but they still don't match the compliance of modern forks. I know there are options available for cartridge type inserts but, from what I have read it seems they cost more and are not as effective as a straight swap for a modern front end. Add to that the fact that I have a spare Excel front wheel and the brake system from my crashed GasGas and it seems a sensible option. It seems a common option is to fit DRZ forks which fit the stem with a change of bearings. I don't have the cash for the custom yokes available over on AdvRider so plan to use a set of DRZ yokes. The GasGas brake calliper is the same as the DRZ, the wheel will fit the DRZ axle with a change of bearings and a 320mm SM disc is available which should be enough to cope with the weight of the G/S.
At the rear I definitely want a new shock as the existing one is from an ST and short compared to the forks. I will probably stick with standard length mono lever but haven't yet ruled out an extension. When cash allows I may also have the rear wheel rebuilt by Haan with an 18" rim rather than the current 17" GS wheel which has limited tyre choice in the narrow widths.
Questions then.
Am I on the right track or is there a better option? Please don't suggest I sell the bike for a modern dirt bike though.
Is there likely to be much demand for the GS front end currently fitted to the bike? My hope is that this will fund the purchase of the DRZ front end making it a free upgrade - I swapped the forks on my X-ch this way.
I am undecided on the shock - emulsion, remote reservoir or a half-way house like the Hyperpro 3D or Nitron which have a separating piston between the oil and nitrogen? l have read that greater travel can be obtained from a standard mono-lever with a custom shock and even steps such as strategically denting the cross member to allow greater clearance. I need a new shock anyway so having a custom shock built is feasible but I don't want to stress the U/J. Also some shocks have a different diameter which can impact on wheel clearance. Any thoughts, particularly those based on experience, would be appreciated.
Is there likely to be a value for the parts I remove?
GS front wheel, forks, yokes brake calliper
Rear rim and spokes. Unfortunately I can't exchange the complete GS rear wheel as the hub was modified to fit the 4 bolt bevel drive.
(the wheels have both been recently rebuilt with black powder coated rims and stainless spokes)
Original ST shock
Eventually a Keihan GS exhaust
I can post them back to UK via BFPO at UK rates, although a courier would be quicker.
Sorry for the rambling post.
Questions then.
Original ST shock
