As aboveWarning, be very careful.... Do not drill too deep, there is an oil way behind the exhaust stud .
Depends on whether you are into engineering , if you are , clean off ( really clean ) then mig weld a nut on from the inside of the nut . Then I would heat the nut till it's really hot , not dripping but bright red , then I would let it cool completely , then tap the nut in a good few times so see if the grip can be broken ,,drown it in plus gas ,, leave for an overnight then try loosening by tapping it again then tightening a wee bit first , then give it a go at winding it back , If you are not accustomed to drilling and tapping , take it to someone who is .
Unless you need to dismantle for a reason which absolutely requires the removal,
leave well enough alone.
Then you do not have a problem.
Myke
Crap advise!
He knows he can’t leave it as it is.
Looks like there is nothing much holding on the exhaust headers...Why not, may I ask?
is dub 24 living in Dublin?
I could help if you have the head off.
Yea, those rotten studs are hidden behind nice shiny chrome domed nuts...
Been there .
If you are indeed in Dublin, I can recommend calling Bert at:
http://www.motoengineering.com
Top work for sure .
Sent from my BND-L21 using Tapatalk
If you fancy doing it yourself Ollie there's a place in Ballymount that sells the cobalt bits and taps.
You need to be bang on centre and have lots of patience.
It took me 2 hours per stud on the CBR
... check the photos on first post?
Cheers mate appreciate your suggestion but unfortunately I am committed to a full on resto and don't want to leave that mess as it is and I realise I am probably giving myself serious ball ache but sher what the hell.I would humbly suggest that I did, and this was the reason for saying: Leave well enough alone. If disturbed, it might mean a heads off job, left alone, may well outlive the bike. More than secure enough as it is.
Until BMW learn to copy the Japanese on how to attach exhaust pipes to bike cylinder heads, this will be an ongoing problem.
Note that, on the new 1250, they have finally recognised that an inverted tooth cam chain is superior to a roller one. Something the Japanese realised 40 years ago.
