roamer
The main crankshaft rear plain bearing ,
is flanged over to control lateral movement and take thrust load,
Don't forget to remove that old gasket sealant from the oil passage.
Thanks again for all the comments.
After reading this thread from first to last post for the first time my comment would be “Put the tools down and step away from the bike”. .
No way, it is all a learning curve, the GS is one of the simplest bikes to work on.
Not seeing where the OP is making it worse or making it hard for a pro to fix,
