Hi all. I need to changes a tubed tyre, having never done this before am after some tips and which are the best tyre levers to get?
Just make sure you get long levers. Tyre changing is mainly down to technique, not expensive levers. I’ve used a pair of cheap levers I bought years ago for less than a tenner, one end is plain the other end is flat hooked to enable you to get it under the tyre rim and lift it over the wheel rim to start you off
Just another thought, would I have to take it somewhere to get it balanced?
If you get the technique right you only need short tyre levers - if you "need" long tyre levers then your technique is wrong
May I ask what the wheel is off??Easy enough to static balance wheels yourself too.
Sent from my G8441 using Tapatalk
Cb500xMay I ask what the wheel is off??
Sent from a U11
I'm 400miles in and it feels fine.
