Oil coller by-pass tube
PW Cymru
Moderator
Mod Squad
Moderator
Nr Cardiff
I need to remove the oil cooler for a while to repair the R/H crashbar as the threaded end has pulled out.
Does any body sell the emergency replacement tubes to remove the cooler.
They also do a little block that serves same purpose, takes up ,less room as a stowed emergency item too.
I’ve got a spare crash bar you can borrow while you sort yours,
Or buy it if you like:thumby:
Cheers Mikey,
I’m going to get the block and probably fit the relocation kit for the cooler.
Will let you know about the spare bar when I get back from hols but cheers for the offer.
