Nippy Normans supply Touratech, Wunderlich and many other makes of accessories. New and secondhand BMW parts.
Results 1 to 14 of 14
Thread: 2008 R1200GS self servicing
  1. #1
    Join Date
    Jul 2008
    Milton Keynes, UK
    Posts
    200
    Question 2008 R1200GS self servicing
    I want to service my 24k mile bike myself.
    The next service includes throttle balance and brake fluid change.
    All relatively straight forward until you read the Haynes and it states that the brake fluid can't be changed as it's needs specialist equipment, (for ABS models). It also warns against the throttle balancing yourself too, recommending main BMW dealer.
    However, they want close to £400 - so self service is my only option this year.
    Any suggestions on work arounds?
    Ollie
    Sex is the breakfast of champions
  2. #2
    Join Date
    Sep 2007
    Wotton under edge
    Posts
    808
    Apparently the partially-integrated ABS system on 07 bikes and later is not too difficult to bleed yourself.
    Throttle balancing can be left out if you don't think its a problem. These bikes are wonky anyway
    Grrrizzly
  3. #3
    Join Date
    Jan 2009
    Marlborough, Wilts
    Posts
    2,870
    I do the brake fluid changes myself on my '08 - seemed easy enough to do at the time with a piece of fuel pipe I had lying around. Since the first time I did it I bought a GS911 which does something to the ABS (not exactly sure what) to make the brake fluid change even better. I think it opens up the ABS modulators so you're changing the brake fluid in there as well as the brake lines/calipers. The GS 911 also allows you to switch off the idle stepper motors to make throttle body balancing easier - I use a Harmonizer to do that bit.
    You can do most of a full brake fluid change without the GS911 and a good stab at the throttle body balancing without one to but it makes life a whole lot easier plus you can reset the service dates. If you're planning to carry on servicing your bike I would recommend buying both (and a BMW Reprom manual) as an investment. There's a few other tools to make life easier (although not essential) such as a coil puller (metal one is better) and a long thin walled plug spanner. The 24K service is a plug change and alternator belt change which is a little more involved but more technique than anything else.
  4. #4
    Senior Member
    Join Date
    May 2011
    Milton Keynes
    Posts
    156
    If you decide you don't want to buy new kit or do it yourself try Churchill Motorcycles for a quote, I suspect they will be near half the cost of Wollaston.
  5. #5
  6. #6
    Join Date
    Sep 2007
    Wotton under edge
    Posts
    808
    Where can you buy a GS911 from?
    Grrrizzly
  7. #7
    Aging 1 eyed Tosser Click here to find out how to Subscribe
    Join Date
    Feb 2005
    The Shire
    Posts
    1,641
    from here
    mummy mummy is dad dead?
    no son hes out riding that bloody gs
  8. #8
    Join Date
    Jul 2008
    Milton Keynes, UK
    Posts
    200
    Quote Originally Posted by Grizzly GS View Post
    http://www.ilexa.co.uk/acatalog/GS-911.html
  9. #9
    What a waste. Click here to find out how to Subscribe
    Join Date
    Oct 2003
    S/W London.
    Posts
    43,854
    Quote Originally Posted by donny1972 View Post
    A little knowledge is a dangerous thing - You've posted the wrong advice for the brakes on a 2008 bike.
    That video is only relevant to the servo equiped bikes. And even then it's making a mountain out of a molehill .
    All your BMW servicing needs at the .gsshop.biz, including 1200 models
    Recommended as an "excellent independant" in Ride magazine 2009.
  10. #10
    Senior Member
    Join Date
    Jan 2013
    uk
    Posts
    106
    Sorry steptoe mines an 04 so this video will apply to me thankfully.
  11. #11
    Join Date
    Sep 2012
    Torbay, England
    Posts
    5,950
    The throttles are easy enough to balance with a Twinmax.
    08 R1200GSA
    76 Suzuki GT750
  12. #12
    Senior Member
    Join Date
    Oct 2007
    Spain/Australia
    Posts
    168
    Food for thought
    Whilst servicing the bike yourself to save money or whilst traveling is not difficult. The only issue is BMW warranty.
    My ABS unit failed the other day on a late 2007 model. My dealer went back to BMW with the full service history of my bike and BMW is supplying a new ABS unit Free of Charge(FOC). I only have to pay the dealer to fit it.
    There is something good to be said in having BMW service your bike.
  13. #13
    Join Date
    Oct 2003
    S/W London.
    Posts
    43,854
    Quote Originally Posted by CliveS View Post
    It also says that even the extra expense of BMW main dealer servicing isn't going to prevent your ABS/servo unit from going tits up.
    So if i was the OP i wouldn't worry about changing the brake fluid.
  14. #14
    Join Date
    Sep 2012
    Torbay, England
    Posts
    5,950
    Click here to find out how to remove these ads
    I ts all about cost now (consider it insurance) if BMW do the service against possible cost later if/when something expensive fails.
    Clutch - probably be classed as wear & tear and there's a lot of labour so not cheap even if the parts are paid for.
    Shocks - Def cheaper for BMW to replace but people rave about Wilbers WESA so there's an excuse to upgrade.
    Corrosion - week & tear
    ABS - Get a used modulator
    Final drive B earings to full rebuild not silly money
    After that it depends on your attitude to risk.
    08 R1200GSA
    76 Suzuki GT750
Posting Permissions
  • You may not post replies
  • You may not edit your posts
