Nippy Normans supply Touratech, Wunderlich and many other makes of accessories. New and secondhand BMW parts  The only BMW motorcycle dealer for Cambridgeshire and South Lincolnshire.
Go Back   ::. UKGSer.com .:: > Technical & Rider > Equipment & Toys > GS Mods
Register FAQ Members List Calendar
GS Mods Modified your GS? Or want to ask a 'How to do question' Post it here
Reply
Thread Tools Display Modes
Old 29-02-08, 21:41   #1
Tunneruk
Crossed to the orange side!
Click here to find out how to Subscribe
Tunneruk's Avatar
R1200GSA Additional rear light/s
Having just fitted a full Les Wassall HiD kit on my 12 a work collegue pointed out after passing him in traffic how insignificant my rear light looked in comparison with the veritable daylight coming from the front. So a plan was hatched.........................
A second rear light fitted to a Wunderlich rear number plate extender and an auxillary light fitted to each pannier.
I took a switched feed from the back of the auxilary socket under the seat up to a relay under the pillion seat plate and fed all three lights from there. the panniers have waterproof quick lock plugs and are a piece of cake to plug in and unplug.
I couldn't be happier with the result!
__________________
Mobile installers of motorcycle accessories and equipment in the South East
07714 266 627
www.ctmotorcycleservices.co.uk
Tunneruk is offline   Reply With Quote
Old 29-02-08, 21:45   #2
Thunder
Subscriber
Thunder's Avatar
Neat install. out of interest where did you source the quick lock waterproof quicklock connectors and how much are they?
__________________
"Insanity does not run in my family, rather, it strolls through, taking it's time, getting to know everyone personally!"
Survived Calum's Road to the Gambia 2010
Thunder is offline   Reply With Quote
Old 29-02-08, 21:58   #3
Davy F
Senior Member
Paranoid
Quote:
It's almost as good as a GoldWing.
Davy F is offline   Reply With Quote
Old 29-02-08, 21:59   #4
Tim Cullis
Motorail expert
Tim Cullis's Avatar
I particularly like the auxiliary lights on the panniers. I found that in Casablanca and other large Moroccan towns the petite taxi drivers are fond of 'lane sharing' and just don't notice the width of the panniers.
__________________
"For sheer delight there is nothing like altitude; it gives one the thrill of adventure
and enlarges the world in which you live,"
Irving Mather (1892-1966)
Access the Morocco GS Knowledgebase
Tim Cullis is offline   Reply With Quote
Old 29-02-08, 22:03   #5
Tunneruk
Tunneruk's Avatar
Quote:
I got all the bits here http://www.dun-bri.com/ I think the plugs + waterproof boots were a couple of quid each.
__________________
07714 266 627
Old 29-02-08, 22:04   #6
Tunneruk
Tunneruk's Avatar
Quote:
It's almost unavoidable really.
__________________
07714 266 627
Old 01-03-08, 09:50   #7
Thunder
Subscriber
Thunder's Avatar
Thanks for that, I like he idea of the lights on the panniers
__________________
Old 11-11-12, 16:12   #8
Ted
Subscriber
Ted's Avatar
Got the insperation so. Just fitted these to the panniers. Easy once you commit to drilling holes in your panniers
Took the feed from the headlight dip beam (yellow wire) so go on/off with the ignition. LEDs so low current and no probs with canbus. Difficult to see the brightness but the same as the tail light. Look neat when off. Overall very pleased.
Now had a practice on mine got to do it all again on Sues….
__________________
Money isn't everything.But it keeps the kids intouch
Ted is offline   Reply With Quote
Old 15-11-12, 21:57   #9
Bendy toy
Subscriber
You could avoid drilling the case with some self adhesive LED repeater lights. Find some that dont have a boss on the back intended to through a car's wing or do some surgery on the boss and seal with electronics grade silicone. Then run the wire along the edge of the case trim with some exterior grade double sided tape.
I have found these connectors to be very tough. They have far more power capacity than needed but they wont fall apart
http://www.ebay.co.uk/sch/i.html?_nk...at=0&_from=R40
Bendy toy is offline   Reply With Quote
Old 15-11-12, 22:03   #10
chad
Subscriber
chad's Avatar
thats a tidy looking job Chris
__________________
Why do people say grow some balls ?
Balls are weak and sensitive,if you wanna get tough ! Grow a pussy..those things can take a real pounding !
chad is offline   Reply With Quote
Old 15-11-12, 22:18   #11
Tunneruk
Tunneruk's Avatar
Quote:
Cheers fella!,
Just got your PM, I'll speak to you tomorrow
__________________
07714 266 627
Old 08-01-13, 17:53   #12
Ted
Subscriber
Ted's Avatar
Better picture of the lights on panniers, as requested. As they do stick into panniers slightly, about20/25mm, made some stainless covers to protect the ends.
Just got to get something to line the panniers with so dont get black alloy rubbings all over stuff but quite pleased with the results and although not to bright during day lights very visable/bright at night.
__________________
Old 13-01-13, 16:06   #13
Ted
Subscriber
Ted's Avatar
Finally finished the lights and made it all tidy. Used some van lining material to line the panniers, no more helmet rattling round or dirty marks on bags etc. We went out on the bikes for the day yesterday and late back so got a good Idea what they are like. Lights are similar in brightness to original so really visible without being too much. Quick release connector’s waterproof and easy to use. Overall very pleased with the end result.
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
