I did some engine mods last week on my '92 GSPD to raise the compression ratio and give it a bit more Ooomph. I put it back together and turned it over with the plugs out...........fine, put the plugs in, fired up at the second go! Ran it down the road, got it warm, tweaked the carbs a little, fine, so endeth Sunday.
Came out Monday morning, fired it up, no problem, got it out, parked it up, got dressed up ready to go out. Fuel on, ignition on pressed the starter............big 'CLICK'............the classic Valeo starter failure 'click'. Checked the battery to make sure it wasn't flat, earth strap off, front cover off, turned the engine over, stiff at first, then heard the starter bendix drop back out of the starter ring, engine free! Valeo Starter off, (wouldn't turn) put the spare Bosch starter on, fired up fine.
Tuesday morning, went to the local electrical suppliers to see what was available, nothing except a new 'Lucas' starter at £214........never, a Nippondenso is only £264 and they're supposed to be the Rolls Royce!
So I stripped the Valeo to see inside..................
Think I might have the Valeo 'magnets unglued' problem!
A bit of research found an updated starter body from EuroMotoElectrics.com with improved glue and spring clips between the magnets to prevent them collapsing inwards and coming unglued. So on Tuesday evening I ordered the EnduraLast version, $39.95 and $41.05 carriage.
10.00am Friday morning the Fed Ex man is at the door with a parcel, it contains.............
By early Friday afternoon I have this............ (note the cut outs in the body sides for the spring clips)
Later on Friday afternoon I have a GSPD with it's Valeo starter rebuilt, fires up better than it did before!
Total cost £53.49.
Total cost £53.49.
