How can you tell the difference between normal headlight and headlight pro on the 1300gs ?
on my 1250gs you could see light beam moving when switched on
Yeh, had a look at the video and it does show the block pattern of the light beam with dark unlit lines going down the hedge rows at the side. But doesn't really use it on more open roads to see it fully.
Not sure anyone knows what the £460 headlight pro actually gives us in practice??. Certainly isn't like matrix headlights in cars where it blanks out only blocks of light to prevent dazzling other traffic but lights up the areas around them. Of course the bike can't do that because it doesn't have a camera, so is headlight pro just a con ??. What is the basic non headlight pro like in comparison?. Has anyone been out in the dark with the standard non pro version and how do they compare.
I found out what the Pro light gives you; --- a cornering light which lights up the inside of the bend as you corner but if you already have the optional BMW Aux lights (fog lights) you hardly notice the Pro cornering light adding anything as the Aux lights already light the area.
