Keba
sn1p3r said:In TomTom v3 you used to be able to select via properties pages which shortcuts you wanted to appear on which pages so that you could put your most frequently used ones on the first options pages, you didn't need to navigate through 5 pages of shortcuts to get to the one you wanted.
See my post above - have to use a 'hack' to change the menus and I'm not totally certain it will work on the 5.4x software until the new SDK is released.
sn1p3r said:In TomTom v3 you used to be able to use the GoTo function to go to a specific GPS coordinates - save them as a favourite and then navigate to that favourite.
See same post above - have to create the item as a POI on a computer using various one of various utilities and then put the POI on the TomTom afterwards. This is not SDK dependant and works quite well imo.
sn1p3r said:One very VERY annoying 'feature' is that as soon as you place it in the cradle and you tap the screen to get to the navigation features it only gives you 4 options. You lose the ability to change from daylight to night colours, you cannot avoid road blocks or navigate around something, you cannot navigate to an address that is not already a favorite. The only way to access these features is to take it out of the cradle - not exactly something you can do while driving or riding your bike!
This should only happen if you are moving - its possible the TomTom thought you were moving and then only displayed the four buttons, but it should fix itself after its sync'd, or after you move a little bit then stop. Personally I would love to see the 'switch day/night' button on that main screen, but I guess the point TomTom are trying to make is this - you shouldn't be concentrating on a small lcd panel and pressing buttons on it whilst moving...
I've noticed too that the RIDER doesn't have ASN whereas the Go does - I'm guessing this is just because the RIDER is much smaller and they couln't fit the hardware that does the ASN calculations in the case - not that its needed imo as the v3 satnav chip hasn't failed me yet and has kept its connection 100% of the time.
sn1p3r said:I really can't believe they have done this, I really feel cheated that I have bought a newer version of a product and have lost a considerable amount of features. It's a pity not one of the 8 reviews I have read highlighted any of these issues.
Apart from the rather annoying menu change upon moving 'feature', I'm not aware of anything thats majorily different between the RIDER using version 5.4x and the Go using 4.x or 5.x (other than the RIDER of course does work with the bluetooth phones it supports whereas the old Classic didn't). Never saw version 3.x of the Go software, so can't comment there.
sn1p3r said:To make things a lot better - you cannot charge your Bluetooth headset while using it because as soon as you plug the charger into the headset it switches itself off.
Now that is indeed going to annoy me something cronic - I was hoping like anything to be able to hardwire the receiver onto my bike :/ I will come up with a solution to this problem eventually, don't you worry! Even if it involves creating a pseudo battery that is actually a link to my bikes battery by pulling the bluetooth dongle apart and hopefully not blowing up the dongle when rewiring it - not that I'm any good at that sort of thing, so maybe I'll buy a spare and play with the spare
I do have a spare charger though, so that stays at work and the other stays at home - to charge it both ends of the journey if needed.
sn1p3r said:TT Support just shrugs their shoulders and says very unsympathetically: 'Thanks for your £600 but you can't do that in this version'.
There is a suggestions area on the TomTom site - I think in the 'Plus' section. I'm going to be suggesting most of my comments above in this and earlier posts, and will no doubt post them again and again every few weeks till they start doing something about it
