Hi,
After some advice on best approach - I've got a Denali smartcan and a set of D2's already from previous bike, my new (to me) 2019 R1250GSA comes with LED fogs .... what is the best solution to re-use the D2's that I have?
Is it to replace the LED Fogs and re-use the brackets on the crash bars for a minimal/clean install? Or add the D2's as an additional set?
Do the LED Fog's flash/come on with Main beam (so would add light when D2's are programmed to come on) or are they completely independent via the switch in which case wouldn't integrate with D2's?
After some thoughts on what others may have done - if I had D4/D7's then would mount additional but D2's are likely just an upgrade over the OEM fogs and not worth purchasing additional mounts to use as may as well go all in with D4/D7's if doing that is my current thinking...
