Thanks Les, money should be winging its way to you now.
Mark
Sent from my GT-I8160 using Tapatalk 2
Mark
Thanks Les, that was quick, fitted sidelight bulb and no more error.
May well be in touch soon about the fast start kit for the high beam, will have a run in the dark to see how effective the BMW led spots are first.
Mark
So.
Not prepared to support the latest government programme then?
MI6 have noted your post
Was riding in the dark for the first time yesterday with the HID and, well, I should have bought it earlier
so how much is one of these kits (discounted to us)? R1200GS, dipped and main beam with a fast start ballast on the main beam, 55w on both...
Cheers,
Marc
Hello Les.
Just bought a Yamaha Super Ténéré, (S10).
Have you supplied HID kit for this bike previously? One of the few problems with the S10 has been with some bikes having headlight wiring and lamp connectors melting, often I think when owners have upgraded the lamps. The standard lamps are rated at 55w each.
On HID's what is the actual power draw, 1) at strike; 2) sustained running for a) 35 watt units; b) 50 watt units? What is the heat output for each burner rating compared with 55w halogen lamps?
I'd like to install a pair of HID's but don't want to run the risk of cooking the wiring 200 miles from anywhere in Scotland on a cold dark night with no mobile phone signal A low temperature colour would be good. You supplied me a burner as a replacement in my 1150 which worked well, about 4k I seem to remember.
To be fair even the standard halogens are so much better than standard 1150GS lamps as there are two for both dip and head using what seems to be a solenoid controlled shutter system to mask the lamps on dip beam.
