XChallenge quick reference thread.
brake discs
I ordered a Grimeca brake disc for the rear of the bike last week but it did not fit and was returned.
Next stop was the EBC website where they list the MD810C, unlike Grimeca this is a different part number than the old F650GS. I ordered this one from brakes4u.co.uk, it arrived the next day and went straight on. :thumb
Take care though. The EBC direct website lists the correct disc in their down-loadable spreadsheet but if you go through online ordering on the website the part number that comes up is the disc for the F650GS.
Have you contacted the suppliers who have to wrong listing and told them that fact?
I try to do this as much as possible to help future punters, which may be you again one day......:thumb2
Talon 13T sprocket
From talon
The sprocket you require TG302 13T is £7.32 + vat. If you wish to order this sprocket please call us on 01935 471508 and press 1 for sales and then 2 for the sprocket department and they will be able to help you
Valve Shims
Copying this over from an ADVrider thread ... the shim part numbers:
Here's the part # listing.
Thickness / BMW part#
2.30mm 11327675540
2.35mm 11327675542
2.40mm 11327675707
2.45mm 11327675709
2.50mm 11327675711
2.55mm 11327675713
2.60mm 11327675715
2.65mm 11327675717
2.70mm 11327675719
2.75mm 11327675777
2.80mm 11327675779
2.85mm 11327675781
2.90mm 11327675783
2.95mm 11327675785
3.00mm 11327675787
Engine re-build gaskets.
If you need to do an engine re-build as i have done three times now,
You can get a full gasket set for around £120.00 from motorworks.
This is the part number , 11117707599 full engine set,
and this is what you get in the set.
07119963276
11112343010
11112343018
11112343019
11117706497
11117706499
11127652921
11127678889
11142343038
11142343240
11142343241
11147699390
11147706498
11147706500
11257652916
11312343091
11347687602
11417652949
11417654013
11517652960
12412343252
21212343259
These part numbers can be looked up on real oem.com.
I also have engine re-build photos if anyone needs them.
Bez.:D
The original story went on here about 3 ish years ago,
the engine consumed itself at 22k ish.(two months out of warranty)
I re built it with a scarver engine parts and ran it to around 78K,then striped it for spares and sold the rest for scrap.
I bought another 07 model low mileage,
striped the engine and made some modifications using a 2001 dakar engine for parts.
I'd buy another one but the wife won't let me.
I only have three other bikes,but the wife said ''one in ,one out'' from now on .
:nenau
Swing Arm Bearings
Having just done them, this is what I needed
Swingarm -
Offside
  • Seal 30 37 4
  • inner ring race 25 30 30
  • bearing 30 37 26 (closed at one end)
Nearside
  • Seal (x2) 25 32 4
  • bearing (x1) 25 32 26
  • shim (x2) 25 40 2.5 bmw part 33 17 7 696 797
2nd time I've done a full set, and still a total pain in the a**e!
Wheel bearings should be sealed. For other applications a good waterproof grease :thumb2
Morning peeps, a bit numpty perhaps but is there a service schedule for longer term stuff, I'm specifically thinking about replacement of the water pump and timing chain tension?
:::.Edit.::: this post has been copied here from this thread.
It seems that I didn't send the new owner the invoice for the parts, after all. So I've no idea what I've done with it.
However, the good news is that I did keep the PM from John Nicholson with the required parts list:
CLUTCH HOUSING COVER 11 14 7 700 331
GASKET 11 14 7 700 194
NEEDLE SLEEVE BEARING 21 21 7 701 501
NEEDLE SLEEVE BEARING 21 21 7 700 120
SHAFT SEAL 21 21 7 700 173
If you want to 100% sort it I normally change the shaft as well :
OPERATING SHAFT 21 21 7 700 306
CIRCLIP 21 21 2 343 258
I got the parts from John Clark Motorrad in Dundee. It took a few days for them to source them from Germany.
HTH
